Vadi96
2 years agoPCIe design example
Hi, We have A10 GX devkit with us and I want to get started with PCIe testing and example designs. I have windows 10 Host PC. Please suggest on how do I get started with PCIe? Example design is ...
Wincent_Altera
2 years agoHi,
You can try to use AN708 that is available for Windows.
- 64-bit Windows driver and application.
- In the package, there is a word document which explains how to install the driver,
- what additional software needs to be installed, and how to run the application.
You may try to run it, if there have any problem, feel free to reach back to us.
Wincent_Intel
- Wincent_Altera2 years ago
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
Else I would like to have your permission to close this forum ticket
Wincent_Intel
p/s: If any answer from the community or Intel Support is helpful, please feel free to give the best answer or rate 9/10 survey.
- Vadi962 years ago
Thanks wchaih for the suggestion. I want to understand clocking structure to PCIe hard IP. What should be the frequency of the clock and how it has to be connected. Can you help me on this? Thanks- Wincent_Altera2 years ago
Hi ,
The frequency of the clock, you may refer to the user guide
https://cdrdv2-public.intel.com/666787/ug_a10_pcie_avmm-683724-666787.pdf
But it depends on which design that you are using either is AVST, AVMM , MCDMA ?Regards,
Wincent_Intel
