16 years agoPCIe Completion ID
I am implementing a PCIe endpoint with the Altera IP. I need to know the endpoint's Completer ID to send it back in the descriptor of read completions. On other core's I've worked with this was out...
16 years agoI think the proper way is to drop in altpcierd_tl_cfg_sample.vhd, you can then get the bus and device number as an output from that port. Seems to work properly in simulation.
