16 years agoPCIe Completion ID
I am implementing a PCIe endpoint with the Altera IP. I need to know the endpoint's Completer ID to send it back in the descriptor of read completions. On other core's I've worked with this was out...
16 years agoDo I need to drop in altpcierd_tl_cfg_sample.vhd from the example design to pull the bus and device number out of the configuration space?
