14 years agoPCIe Bus#, Device# and function field
Hi, 1. I have some confusion about the bus number and device number we use in TPLs. For example if i connect a root complex with a native end point.... what will be the bus and device number...
14 years agoHi,
Have you resolve this problem ? I have the same problem when I try to use the altera pcie rootpoint to train the altera pcie endpoint. I can perform the mem wr transaction from root to end, but when I perform the mem wr from end to root, there is nothing in the avalon-st interface of the rootpoint. Is it the problem of the configuration ?
