14 years agoPCIe Bus#, Device# and function field
Hi, 1. I have some confusion about the bus number and device number we use in TPLs. For example if i connect a root complex with a native end point.... what will be the bus and device number...
14 years agoI recommend you to try Jungo's windriver.
"It is free for first 30 days" You can at least perform config-read and endpoint read/write by using bar. so you can see if your h/w setting is correct or not. As far as I know, the PCIe core's config registers are working fine. I believe you can confirm your 1,2,3 by using the tool that comes with the Jungo's driver.
