10 years agoPause needed between multiple DMA transfers?
I try to sequentially read buffers from PIO at the fastest possible
speed with NIOS II/f. Everything works fine, however the speed seems to be limited to ~25 MB/s, independently of the buffer size. The essential part of the C-code is: --- while (Nr < NrBuffers) { Nr++; if ((rc = alt_dma_rxchan_prepare(rxchan, rx_buffer, NrBytes - 1, done, NULL)) < 0) { printf("Failed to post read request, reason = %i\n", rc); exit(1); } while (!rx_done); // wait for transfer to complete ; // necessary pause usleep(40); } --- With NrBuffers= 100000 and NrBytes= 1000 ( a total of 100 MByes) this takes about 4 s, hence the ~25 MB/s. Note that usleep(40) alone accounts for the entire 4 s (40E-6x1E5= 4 s). Larger buffers need larges pauses, hence the aforementioned maximum speed of ~25 MB/s. However, with the shorter pause usleep(30) alt_dma_rxchan_prepare gives error message -28= ENOSPC= No space left on device. In addition, the program starts at the top, resulting in an infinite loop of starts and ENOSPC messages. . On the other hand, usleep(30) with a small NrBuffers= 5 works fine. Apparently, calling many alt_dma_rxchan_prepare's too fast (although the data is transferred) after each other is upsetting things seriously. I tried to adjust some settings of the DMA core (enable burst transfers, larger FIFO depth) to no avail. Any idea how I can solve this? Thanks! Jos2 Replies
Your description sounds like you have a bug in your done() callback and rx_done handshake. For example, you might get the behavior you described if you had never reset rx_done back to zero before starting the next transfer.
You are completely right, thanks! I copied the done() and rx_done part from somewhere
without giving it sufficient attention. By resetting rx_done back to 0 when needed I can now omit the usleep(). However, I still am stuck at the ~25 MB/s. The next puzzle...
