8 years agoParallel Flash Loader For MAX II .
Hi Everyone, I am using the Parallel flash loader for CPLD to configure an FPGA using an on board NOR flash. I have been able to generate the IP by following AN478 and AN386. I have i...
8 years agoHi,
--- Quote Start --- My question is , do I have to generate the test bench for the flash_inst, which is calling the Flash IP? --- Quote End --- Not required. Refer the “Using the PFL in the Quartus II Software” from the AN386. https://www.altera.com/ja_jp/pdfs/literature/an/an386.pdf 1. Intel/Altera recommends setting all unused pins to tri-state. 2. Instantiate the PFL Megafunction in the Quartus II Software by referring “Instantiating the PFL Megafunction in the Quartus II Software”. 3. Then obtain .pof file for Flash device. 4. Program the Flash device by referring “Programming MAX II and Flash Devices” Which Quartus Edition & Version are you using? Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
