Likewise
5 years agoP-tile PCIe what if is rx_st_ready_i deasserted?
If the application deasserts rx_st_ready_i, what does this mean for the endpoint behaviour regarding the TLPs that are inbound towards the FPGA? Will these TLPs be dropped in PCIe core?
I.e. is it...
Deshi_Intel
5 years agoHI,
You can find the explanation of rx_st_ready_i signal in user guide doc (page 57)
Pls see my reply below.
- If the application deasserts rx_st_ready_i, what does this mean for the endpoint behaviour regarding the TLPs that are inbound towards the FPGA? Will these TLPs be dropped in PCIe core?
- If rx_st_ready_i is deasserted by the Application Layer on <n> cycle , the Transaction Layer in the PCIe Hard IP continues to send traffic up to <n>+ readyLatency cycles after the deassertion of rx_st_ready_i. P tile ready latency is 27 clk cycles.
- You can refer to further explanation and timing diagram in chapter 4.4.3. Avalon-ST RX Interface rx_st_ready Behavior (page 62)
- is it even allowed to deassert rx_st_ready_i for a well-behaving PCIe endpoint ?
- The answer is YES but not recommended. Ideally to achieve the best performance, the Application Layer must include a receive buffer large enough to avoid the deassertion of rx_st_ready_i
- This is just extra back pressure mechanism available for the application host to use if they need to
In short, when application layer deassert rx_st_ready_i, P-tile hard IP will gradually stop transferring TLP packet back to host and it will resume the packet transfer once rx_st_ready_i is asserted back
dlim
