danield17
1 year agoOver 4GB PCIe BAR Size Issue
Hi, I created a design that utilizes the Arria 10 Hard IP and an EMIF. On my board, I have 8GB of DDR memory, and I wanted to connect one of the PCIe BARs to the EMIF so I could read from and write...
VenT_Altera
1 year agoHi Daniel,
I will look into your issue with the PCIe IP.
Could you please share the pcie.ip file used in your design? I would like to understand further the parameters and settings you have configured.
Ven
danield17
1 year agoHi Ven,
Sorry for the delay in getting back to you.
I’ve attached the PCIe IP file along with the Quartus project in case you’d like to take a look.
As I mentioned earlier, everything worked fine when I was using the burst master.
The issue only came up when I used the BAR2 master without bursting.
The DMA master interface is also connected to the EMIF, and with DMA, both reads and writes work as expected. But with the BAR2 master, it didn’t work.
Daniel
