danield17
1 year agoOver 4GB PCIe BAR Size Issue
Hi, I created a design that utilizes the Arria 10 Hard IP and an EMIF. On my board, I have 8GB of DDR memory, and I wanted to connect one of the PCIe BARs to the EMIF so I could read from and write...
danield17
1 year agoHi Adzim,
I’ve already created a design that uses DMA and the Address Span Extender, with my BAR set to 2GB, and everything worked fine.
I haven’t tried the EMIF example design, but I’ve confirmed that I can read and write to the DDR using both the DMA and the BAR master.
After investigating the issue, I found that read and write operations only work for me when the PCIe Hard IP is configured with burst enabled for the BAR2 master.
Is there a reason it only works with the burst master? Could it be something internal to the PCIe IP?
Did I miss something that would cause it to work only in burst mode?
Do you still want snapshots and the DDR datasheet? If so, how should I provide the snapshots—images?
Daniel
VenT_Altera
1 year agoSee below message.
