danield17
1 year agoOver 4GB PCIe BAR Size Issue
Hi, I created a design that utilizes the Arria 10 Hard IP and an EMIF. On my board, I have 8GB of DDR memory, and I wanted to connect one of the PCIe BARs to the EMIF so I could read from and write...
AdzimZM_Altera
1 year agoHi Daniel,
"Do you still want snapshots and the DDR datasheet? If so, how should I provide the snapshots—images?"
- Yes, you can send the EMIF IP setting in the PDF and DDR datasheet in PDF.
- I know the operation is running okay, but let start to debug at EMIF IP first.
- Then, can check the other.
For the burst mode questions, the PCIE expert will comment later.
Adzim
