9 years agoOutputs from decimatingCIC are shifted (i.e. input at channel c2 appears at c0)
Hi everyone, I have a problem with the Decimating CIC filter with multi-channel input, generated by DSP Builder. The settings are as following: Input Rate per Channel/MSPS : 20 Number o...
9 years agoThank you again Kaz,
I have connected the data, valid, and channel right infront of the Filter to ChanView. The output signals from channel view was as expected, no shift at the input. All data are displayed at the proper channels. However, I tried to delay only the data line by 1 sample delay. As a result, CICfilter outputs are now in the right order. I think this is might be only a temorary solution because once I do this the data and channel number are not aligned at the input of CICfilter any more. Could it be that there is a missing sample delay in the DecimatingCIC filter because I have to compensate it in front of the block? Thank you very much.
