9 years agoOutputs from decimatingCIC are shifted (i.e. input at channel c2 appears at c0)
Hi everyone, I have a problem with the Decimating CIC filter with multi-channel input, generated by DSP Builder. The settings are as following: Input Rate per Channel/MSPS : 20 Number o...
9 years agoalso remember these are meant to be channels and will also get decimated so your observation is not that easy. put zeros in all except one at a time and see
