9 years agoOutputs from decimatingCIC are shifted (i.e. input at channel c2 appears at c0)
Hi everyone, I have a problem with the Decimating CIC filter with multi-channel input, generated by DSP Builder. The settings are as following: Input Rate per Channel/MSPS : 20 Number o...
9 years ago --- Quote Start --- Hi everyone, From these setting I need to feed input vector of 7 because each input has TDM of 5 (100MHz/20MHz). --- Quote End --- can you explain the above, I don't get it. are the 32 channels serial or parallel?
