output data format of FFT IP core
As I understand it, you have some inquiries related to the FFT IP. For your information, it is recommended for you to perform a Modelsim simulation with your targeted configuration and input data to verify the expected output. Also, Modelsim simulation will help to isolate any functional problem prior to hardware testing.
By the way, just to ensure we are on the same page, would you mind to further elaborate on the following:
1. What is the Quartus edition that you are using? I understand from the screenshot that you are using version 18.1.
2. Mind further elaborate one the "Q17 format" that you are referring to?
Thank you for the reply
Like you said i am doing simulation in modelsim and
1. Version of Quartus prime is 18.1.
2. In fixed point representation, Q17 format means out of 18 bits of data, MSB bit(18th bit) will be the sign bit and rest of the data will be fractional bits. So if i give the data like this what would be the output format?
