18 years agoOpencore Plus Hardware Evaluation
Hello, I've downloaded and installed the MegaCore IP Library and i've simulated my design using two cores: Reed Solomon Decoder and Viterbi Decoder and now I want to perform the time-limited hardw...
18 years agoThe issue isn't with OpenCore Plus. You simply can't compile the design period because Quartus II isn't finding all the files for the IP core. This is a periodic problem with Altera IP. More recently, they've switched to using a special file called a QIP file that tells Quartus II where to find the source files for the IP core. I usually workaround the problem by adding the lib directory for the IP core to my User Libraries path.
