18 years agoOpencore Plus Hardware Evaluation
Hello, I've downloaded and installed the MegaCore IP Library and i've simulated my design using two cores: Reed Solomon Decoder and Viterbi Decoder and now I want to perform the time-limited hardw...
18 years agoIt's used automaticly for IPs not covered by your installed license. Or do you get an error when trying to compile a design that uses the IPs?
