19 years agoOpen Core IP time limited source files expired.
hi, after using Quartus II 7.0 full version and the NIOS 2 open core plus for a week. I could not synthesize my NIOS 2 system since the cpu.v is a time-limited files. do you guys have this problem? ...
14 years ago --- Quote Start --- Hi Dimo I have seen this before with opencore / opencore plus. The problem you are seeing is because you have 3rd party simulation enabled (hence the EDA netlist writer is running, which is where the error is being seen). Opencore plus does not allow creation of simulation netlists. Try turning this option off under settings->eda tool settings->simultion. (select no simulator) If this still doesn't work try removing the PCIE. Cheers --- Quote End --- thank you for your advices, and I try your method ,but it work successfully.However ,I want to ask modelsim for simulation, I can't close the 3rd party simulation , how I can do to solve this problem Error: Can't generate netlist output files because the file "D:/altera/10.1/quartus/qdesigns/FFT/FFT1/fft-library/asj_fft_wrengen_fft_101.vhd" is an OpenCore Plus time-limited file
