19 years agoOpen Core IP time limited source files expired.
hi, after using Quartus II 7.0 full version and the NIOS 2 open core plus for a week. I could not synthesize my NIOS 2 system since the cpu.v is a time-limited files. do you guys have this problem? ...
18 years agoWhat device have you chosen? If you chose a device that has programmer support, you should be able to program the FPGA using the OpenCore Plus hardware evaluation feature for any design that contains Altera IP. You do not need to have a license. OpenCore Plus hardware evaluation is time-limited, but as long as your programmer is connected to your board your design should continue working in hardware.
Can you also tell me which IP cores you are using? Perhaps you are using non-Altera IP. Perhaps you should contact Altera technical support. I would guess that you just need some help getting started.
