19 years agoOpen Core IP time limited source files expired.
hi, after using Quartus II 7.0 full version and the NIOS 2 open core plus for a week. I could not synthesize my NIOS 2 system since the cpu.v is a time-limited files. do you guys have this problem? ...
19 years agothis is the error message:
Info: Running Quartus II EDA Netlist Writer Info: Version 7.1 Build 156 04/30/2007 SJ Full Version Info: Processing started: Tue Jul 24 11:32:08 2007 Info: Command: quartus_eda --read_settings_files=off --write_settings_files=off niosbase -c niosbase Error: Can't generate netlist output files because the file "C:/PCIE/niosbase/cpu.v" is an OpenCore Plus time-limited file Error: Can't generate netlist output files because the file "C:/PCIE/niosbase/cpu.v" is an OpenCore Plus time-limited file Error: Can't generate netlist output files because the file "C:/PCIE/niosbase/cpu.v" is an OpenCore Plus time-limited file Error: Can't generate netlist output files because the file "C:/PCIE/niosbase/cpu.v" is an OpenCore Plus time-limited file Error: Quartus II EDA Netlist Writer was unsuccessful. 4 errors, 0 warnings Info: Allocated 118 megabytes of memory during processing Error: Processing ended: Tue Jul 24 11:32:10 2007 Error: Elapsed time: 00:00:02 Error: Quartus II Full Compilation was unsuccessful. 4 errors, 112 warnings
