18 years agoOn chip terminations cyclone III
Is the on chip termination available on these devices good enough to eliminate external source termination? The reason I ask is that it does not look like it is being used on the kit boards - I still...
18 years agoYes, that is a good one. As far as fast goes, a part like the TI sn74cb3t3384 bus latch can't be beat. Which CII board did you originally use? Did it work well for you? If you did not use an HSMC connector on your new board what did you use?
