17 years agonumerical representation help
i tried a simple model such as following:
a constant block with value -8/3 connected to five inputs are set as following: 1: Bus Type = Signed Fractional Number of Bits [.] = 5 [.] Number of Bits = 0 2: Bus Type = Signed Fractional Number of Bits [.] = 4 [.] Number of Bits = 1 3: Bus Type = Signed Fractional Number of Bits [.] = 3 [.] Number of Bits = 2 4: Bus Type = Signed Integer Number of Bits [.] = 4 [.] Number of Bits = 1 5: Bus Type = UnSigned Integer Number of Bits [.] = 3 [.] Number of Bits = 2 all the inputs are connected to a Multiplexer then to a Display the figure of the model is attached. when i start simulation, i get error complaining the mixed data type. any advice?3 Replies
You're not allowed to use a Simulink mux like that. Simulink muxes create "vectors" of signals and as such each signal must be of the same type. You could convert them all to the same type before connecting them to the mux or you could just create a scope with 5 inputs and connect them directly to the scope.
Within Altera input and output blocks, almost Simulink blocks are allowed (the only exceptions that I can think of are the subsystem block and the scope block). It's illegal to mix and match simulink and Altera blocks like that. If anything, you would have to convert them back to Matlab type before you can use the mux.
You can also use From and Goto blocks.
