Kavin
5 years agoNo response when alpplying write on avl_mm port when using generic serial flash interface IP
when I apply memory write with generic serial flash interface IP,there is no response on QSPI physical pins,but these pins response correctly when applying write enable or memory read.
Hi
Thanks,the problem is solved.In my design ,the burstcount default value is 0 and i forgot to change it's value.
- Kavin
what is the right step to apply memory write?
- YuanLi_S_Intel
You may refer to the user guide at below for the steps to perform write operation:
Thank You
- Kavin
Hi
- YuanLi_S_Intel
I am glad it is solved now
