Kavin
5 years agoNo response when alpplying write on avl_mm port when using generic serial flash interface IP
when I apply memory write with generic serial flash interface IP,there is no response on QSPI physical pins,but these pins response correctly when applying write enable or memory read.
- 5 years ago
Hi
Thanks,the problem is solved.In my design ,the burstcount default value is 0 and i forgot to change it's value.
YuanLi_S_Intel
5 years agoHi,
You may refer to the user guide at below for the steps to perform write operation:
Thank You
Kavin
5 years agoHi
