Kavin
5 years agoNo response when alpplying write on avl_mm port when using generic serial flash interface IP
when I apply memory write with generic serial flash interface IP,there is no response on QSPI physical pins,but these pins response correctly when applying write enable or memory read.
- 5 years ago
Hi
Thanks,the problem is solved.In my design ,the burstcount default value is 0 and i forgot to change it's value.
Kavin
5 years agowhat is the right step to apply memory write?
