14 years agono free buffers for rx
Hello How do i increase the receive buffer size.... till now i have done following... 1. increase the receive Depth of TSE Mac... 2. Increase the MAXBIGPKTS from 30 to 512 in "ipport.h" ...
14 years ago --- Quote Start --- If you use the offload example, you need to use the dedicated hardware to handle your high bandwidth traffic. If you use the TCP/IP stack then you will have the same problem. --- Quote End --- hardware which download from alterawiki "http://www.alterawiki.com/wiki/Nios_II_UDP_Offload_Example" probably dedicated hardware for this. regards kaushal
