14 years agono free buffers for rx
Hello How do i increase the receive buffer size.... till now i have done following... 1. increase the receive Depth of TSE Mac... 2. Increase the MAXBIGPKTS from 30 to 512 in "ipport.h" ...
14 years agoDid you use the "reassign base address" option afterwards? It should move all your components addresses again, and hopefully solve the overlap problems.
I see you have an Avalon Clock crossing bridge too, try to lock it to address 0 too if you still have problems. I think it is the one responsible for the last error (ddr2_bot.s1 appears at more than one address). Also check that you don't have any component with an Avalon Slave interface that is connected to both sides of a pipeline bridge. This could confuse SOPC builder.
