14 years agoNIOS2 to 8 bit MM slave block data transfer -- Help
Hi, I Have a 8bit addressed , 8bit width FIR IP module which i want to interface with NIOS2. My Module is interfaced with 1. MM Slave Interface 2. Interrupt Sender 3. Clk input. ...
14 years agoI think your offset is wrong. 0x1F0 is "1 1111 0000" in binary which doesn't fit in your 8 bits of 1-byte addresses. I think you want to do this instead if I understand your addressing scheme:
IOWR_8DIRECT(FIR_INTERRUPT_0_BASE, 0x7C, 0x03);
