NCO simulation
I’m using Quartus lite edition and Intel Questa to develop my application. My application uses the NCO IP and I’m able to compile the design correctly but I’m not getting the NCO outputs toggling in the RTL simulation using Intel Questa. The Sin, Cos and the valid outputs are all in the U state although I’m not getting errors or warnings in Intel Questa. I wrote a simple design, a wrapper code (attached) to simplify the design and simulate the NCO IP and still the Sin, Cos and the valid outputs are all in the U state using Intel Questa RTL simulation. What could be the cause and how to simulate the NCO IP using Intel Questa? Please note that the .qip and the .sip files are added to the project.
Since you are using the Quartus Lite version, have you tried using the Nativelink simulation flow?
The Nativelink feature automatically compile your design, Intel IP, simulation model libraries and testbench.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
- Fuad1
I would like to add that I'm getting the warnings in the attached file from Intel Questa when I try to simulate.
- FvM
"instance xxx not bound" is the relevant warning. It means that the nco IP can't be found by the simulator. Did you generate simulation code by the IP generator and added it to the Questa project? Encrypted synthesis source files can't be used by the simulator. - RichardT_altera
Richard Tan
- RichardT_altera
May I know does my latest reply helps?
Richard Tan
- Fuad1
Yes, it helped. Problem is solved. Thank you.
Fuad
- RichardT_altera
Thank you for acknowledging the solution provided. I'm glad to hear that your question has been addressed. Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out.
Richard Tan
