Fuad1
3 years agoNCO simulation
I’m using Quartus lite edition and Intel Questa to develop my application. My application uses the NCO IP and I’m able to compile the design correctly but I’m not getting the NCO outputs toggling in ...
- 3 years ago
Since you are using the Quartus Lite version, have you tried using the Nativelink simulation flow?
The Nativelink feature automatically compile your design, Intel IP, simulation model libraries and testbench.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
FvM
3 years ago"instance xxx not bound" is the relevant warning. It means that the nco IP can't be found by the simulator. Did you generate simulation code by the IP generator and added it to the Questa project? Encrypted synthesis source files can't be used by the simulator.
