HypeInst
5 years agoNCO IP uses far too many M10K blocks
When I add one (1) NCO from Intel's IP Catalog to my design, the M10K-block usage increases by 576, exceeding the capacity of the Cyclone V device.
The Intel NCO IP Core User Guide states that M10K...
Nurina
5 years agoHi,
The user guide numbers are only for a particular (unspecified) configuration of the NCO.
In multiplier-based architecture, every two bit increment of the angular resolution doubles the required depth of the memories. At 16 bits, only 2 M10Ks are required. So you'll have to reduce the angular resolution to reduce the M10K usage.
Let me know if you have any more querries.
Nurina
HypeInst
5 years agoHi Nurina,
I understand. Thank you for your research time and response!
HypeInst
