HypeInst
5 years agoNCO IP uses far too many M10K blocks
When I add one (1) NCO from Intel's IP Catalog to my design, the M10K-block usage increases by 576, exceeding the capacity of the Cyclone V device.
The Intel NCO IP Core User Guide states that M10K...
Nurina
5 years agoHi,
I'm able to see that the NCO IP is using 576 M10K blocks.
Can you try using CORDIC generation algorithm instead of multiplier-based to see if it satisfies your requirement even though it has lower FMax.
Can you let me know why you want to use multiplier-based?
Nurina
- Nurina5 years ago
So I tried using the CORDIC generation algorithm and it uses an expected amount of M10K memory blocks, but with a lower Fmax (also expected). Would this satisfy your design needs?
Nurina
- HypeInst5 years ago
Hi Nurina,
I prefer to use a multiplier-based NCO due to application performance requirements. I'll be happy for this issue to be reported to the correct department to be corrected in a future Quartus Prime release.
Thank you and regards,
HypeInst
