dinkersemwal
5 years agoNCO IP output is shifting wrt output valid on aria10 eval board
Hi All,
I am using intel NCO IP as DDS to generate a LO for the mixer.
when i am testing my module on board(aria10 eval), i observe that output sample is shifting by one clock (back and forth wit...
- 5 years ago
This might be related to the reset, you probably need to hold the reset for a few clock cycles while the clken is asserted.
Regards -SK
SengKok_L_Intel
5 years agoIn the user guide, it states the reset is asyn, however, based on the waveform, the reset is de-asserted during the clk_en is asserted.
