dinkersemwal
5 years agoNCO IP output is shifting wrt output valid on aria10 eval board
Hi All,
I am using intel NCO IP as DDS to generate a LO for the mixer.
when i am testing my module on board(aria10 eval), i observe that output sample is shifting by one clock (back and forth wit...
- 5 years ago
This might be related to the reset, you probably need to hold the reset for a few clock cycles while the clken is asserted.
Regards -SK
SengKok_L_Intel
5 years agoHi,
Do you reset the NCO IP after the input clock of NCO is stable? When the problem happens, if you issue a reset, does it remain the same?
Regards -SK
dinkersemwal
5 years agoHi SK
>>once clock is stable and module reset is de asserted, i am not resetting the NCO again.
but in simulation i observed that when i force reset in between the behavior is same as observed on board.
thanks & Regards
Dinker
