NCO IP output is shifting wrt output valid on aria10 eval board
- 5 years ago
This might be related to the reset, you probably need to hold the reset for a few clock cycles while the clken is asserted.
Regards -SK
Did you reset the NCO IP after power up? Does the behavior change after each reset?
In order to better understand the problem, it will be helpful if you can attach the waveform of your simulation and hardware result.
Regards -SK
Hi SK,
thanks for the response.
This behavior is not very consistent it is coming once in very 8 to 10 reboots.
and output is not just one sample shifted but samples are totally different some times.
>>Yes NCO gets reset after Power up, but behavior doesn't change at every reset. it changes after reboot.
i am attaching the simulation and the signal tap wave form.
simulation captures expected samples .
and signal tap capture change in the behavior
Dinker
