13 years agoNCO and FIR COmpiler Megafunction performance
For learning purpose, I just added two NCO O/Ps with 1 MHz and 5 MHz. NCO1 = 1 MHz NCO2 = 5 MHz and using FIR Compiler unit ( with Fc = 1.25 MHz), I filtered the mixture of these t...
13 years agoFor understanding the effect of no. of bits of output, i wrote a simple code :
module testing (in1, in2, out,out1, out2);
input in1;
input in2;
output out;
output out1;
output out2;
assign out = in1 + in2;
assign out1 = in1 + in2;
assign out2 = in1 + in2;
endmodule this design i simulated with unsigned decimals. in1 and in2 = 1 to 36; the various outputs are as shown in attachment. http://www.alteraforum.com/forum/attachment.php?attachmentid=6206&stc=1&d=1345964169 The same design i simulated for signed decimal input. and result is : http://www.alteraforum.com/forum/attachment.php?attachmentid=6207&stc=1&d=1345964401 CLEARLY : I believe, in verilog, if we assign a higher no. of bits to output, the result doesnt vary or affected by the nature of input viz. signed/unsigned etc. what do u think ??
