13 years agoNCO and FIR COmpiler Megafunction performance
For learning purpose, I just added two NCO O/Ps with 1 MHz and 5 MHz. NCO1 = 1 MHz NCO2 = 5 MHz and using FIR Compiler unit ( with Fc = 1.25 MHz), I filtered the mixture of these t...
13 years agoMy eyesight is gone??
OK in that case if you save your NCO1,NCO2, adder, filtered output to work space as array and attach it to your post then I might get better eyesight
