13 years agoNCO and FIR COmpiler Megafunction performance
For learning purpose, I just added two NCO O/Ps with 1 MHz and 5 MHz. NCO1 = 1 MHz NCO2 = 5 MHz and using FIR Compiler unit ( with Fc = 1.25 MHz), I filtered the mixture of these t...
13 years agoAre you sure about your figures? NCO1 is meant to be 1MHz yet you have several cycles over 1000ns interval as per your diagram(you should have one cycle running for 1000ns period). it is probably 10MHz.
