Sean2
5 years agoNative Floating Point DSP Intel Arria IP
When I used the Native Floating Point DSP Intel Arria IP on Quartus Standard Edition 18.1 and 20.1, the clock input signal is a type conduit instead of a clock input. I am not able to connect anythin...
CheepinC_altera
5 years agoHi,
As I understand it, you have some inquiry related to the port type of the clock input for Native Floating Point DSP Intel Arria IP. Sorry as I do not have specific answer to why the conduit type are different between Quartus Std vs Pro. However, as I understand it, generally the new enhancement will only be in Pro version.
As a workaround, you might need to export out and connect the clock at RTL. Sorry for the inconvenince.
