17 years agoMultiply add Block and How to cope with the problem of the lack of ressources
Hi, I'm still using DSP Builder 6.0 on Matlab 7.01. In fact, after analysing , place an route my model, I'm confronted with a lack of ressources in my FPGA on Dsp Board EP2S180. - 222% utiliza...
17 years agoHi,
Well, hand-crafting FPGA is by far best for resource. Tools like DSP builder are not that mature yet...but may accelerate the design in some cases or may make it worse producing a pile of garbage. TDM is time sharing i.e. if I can run at say twice data speed then I can have one multiplier do the job in first cycle for one data then same multiplier do the job for next data(this is minimum TDM factor , =2 and can be higher). Datawidth if say is 19 bits then it will waste a lot since most altera multipliers are of 9bit graininess. There are some other points: 9) use power of 2 shift to replace multipliers 10) look for zero multiplicand cases. These cases you know the result?? Kaz
