17 years agoMultiply add Block and How to cope with the problem of the lack of ressources
Hi, I'm still using DSP Builder 6.0 on Matlab 7.01. In fact, after analysing , place an route my model, I'm confronted with a lack of ressources in my FPGA on Dsp Board EP2S180. - 222% utiliza...
17 years agoHi,
In a very general sense: 1) reduce your multiplication at source 2) think of time sharing(TDM) if you can go faster... 3) reduce datawidth to 9 bits or less than 18 bits 4) think of using soft multipliers(horrible on memory) 5) use addition if you can to replace or pre-add then multiply 6) think of any possible premultiplication of results and store in LUT 7) use larger device 8) avoid DSP builder, Do it Yourself 9) give up Regards Kaz
