13 years agoMulti-Rate Designs
Hi, I'm having a problem driving different blocks of my design with different clock rates. Suppose I want the following system: Input Signal (50 MSPS) --> CIC Filter (decimate by 25) --> F...
13 years agoThe compare conditions in post# 1 aren't exactly clear to me. Do you run the same filter h(n) with different sample rates?
In a realistic testbench, the filter should be calculated for 2 MSPS input rate, sink_valid supplied with a 2 MHz clock enable and the test signal clocked at the same rate.
