SharmaUmesh278
2 months agoMT25QL128 Not Available in ALTASMI_PARALLEL Configuration Device List
Hi everyone, I'm working on a design with Cyclone FPGA(s) in a master/slave (active/passive) configuration, using a Micron MT25QL128 flash device for FPGA configuration storage. While trying to ins...
umut_arrow
2 months agoHi,
I believe the right choice for Micron MT25QL128 is EPCQ-A configuration (EPCQ128A).
The reason ASMI Parallel IP only lists EPCS/EPCQ, but Convert Programming File tool lists MT25Q, this is most likely because they're separate tools. Nonetheless, the tool with target the flash device correctly in Active Serial programming.
In terms of the known issues, I can see a couple when I searched the Forums and the Knowledge Base, but all of them seem to be fixed with an older version of Quartus.
https://community.altera.com/kb/knowledge-base/how-do-i-enable-microns-mt25q-device-support-in-replacement-to-end-of-life-eol-e/345149
