MSI generation in PCIe
We have been trying to generate MSI interrupt through the RXM_irq input port by making it external on the platform designer. We do not have a DMA engine connected to PCIe, but if look at the testbench system created, specifically at altpcietb_bfm_driver_avmm.v, The MSI interrupt generation is only in dma_mem_test and not on the target_mem_test. We have connected bar0 to the CRA port in our design and hence we are using target_mem_test_lite in this driver BFM. I have modified the testcase similar for this at target_mem_test_lite from dma_mem_test for MSI interrupt generation (Please refer to the attached file).
After writing register 0x50 to 0x00010000 (Bit 16 is used for MSI enable) (cra_msi_enable.png), When we try to read Interrupt Status Register (0x0040), the value we read is 0x0 (Refer to attached snapshot (cra_read_rxm_irq.png).
Could anyone please guide us on how to properly generate MSI interrupts with these configurations.
We are also attaching the Archived Quartus project for reference.
Sudhansh Garg
- Rahul_S_Intel1
Hi ,
As primary information, is the MSI enable bit is set
- Sudhirkv
Hi Rahul,
Thanks for your time.
Yes we have set the msi_enable bit set to 1.
We have also attached the testbench file in the earlier post.
Sudhir
- Rahul_S_Intel1
Can you please help to give your number in private message , so that I can call you.
