Sudhirkv1
5 years agoMSI generation in PCIe
We have been trying to generate MSI interrupt through the RXM_irq input port by making it external on the platform designer. We do not have a DMA engine connected to PCIe, but if look at the te...
Rahul_S_Intel1
5 years agoHi ,
As primary information, is the MSI enable bit is set
Sudhirkv
5 years agoHi Rahul,
Thanks for your time.
Yes we have set the msi_enable bit set to 1.
We have also attached the testbench file in the earlier post.
Sudhir
- Rahul_S_Intel15 years ago
Can you please help to give your number in private message , so that I can call you.
May I kindly close the issue, as the issue is open for quite a long time. Kindly requesting to open a new thread if the issue is still open
Kindly let me know if you have additional questions
