10 years agomsgdma stuck in busy state
Hello :) I have a problem with the msgdma. When I submit a descriptor to it and set the go bit it keeps in busy state. I'm using the SoCKit with Cyclone V and Quartus 14.1 The msgdma ...
9 years agoMe too, actually. The reply was basically that there was a bug. If you read the release notes for Quartus, it sounds like the FIFO reset bug is fixed. I haven't tested it though as I built a workaround in RTL to manage the FIFO bug. The mSGDMA has been working pretty well.
