10 years agomsgdma stuck in busy state
Hello :) I have a problem with the msgdma. When I submit a descriptor to it and set the go bit it keeps in busy state. I'm using the SoCKit with Cyclone V and Quartus 14.1 The msgdma ...
10 years ago --- Quote Start --- I think that the Avalon-MM BFM simulates the IP generated by Qsys, not the hard IP used by the ARM core. It may not be a valid simulation. --- Quote End --- I've been using the mSGDMA Qsys IP-- not the Arm DMA IP. I haven't run a simulation, but the Arm DMA IP is the Corelink DMA-330-- this is a very different beast.
