10 years agomsgdma stuck in busy state
Hello :) I have a problem with the msgdma. When I submit a descriptor to it and set the go bit it keeps in busy state. I'm using the SoCKit with Cyclone V and Quartus 14.1 The msgdma ...
10 years ago --- Quote Start --- Hello Bob, Thanks for your post. I followed your advice but this didn't solve the problem. You can see my configuration at the picture (https://www.dropbox.com/s/d7174gyidtpgzqf/qsys_msgdma.png?dl=0, I need to do it that way because the forum does resize it when I upload it... unreadable...). I will keep on trying to get the msgdma to work... I'm open for ideas and hints:confused: Tom --- Quote End --- Interesting, Tom. Your mSGDMA settings are almost identical to mine except that my max transfer size is 4096 bytes, so max burst count is 256. Sorry this didn't work for you. I'll post back with whatever I learn about the problem I was having. More testing required. Bob
