10 years agomsgdma stuck in busy state
Hello :) I have a problem with the msgdma. When I submit a descriptor to it and set the go bit it keeps in busy state. I'm using the SoCKit with Cyclone V and Quartus 14.1 The msgdma ...
10 years ago --- Quote Start --- So my advice is to configure your mSGDMA burst size to be the same size as your configured maximum transfer size and see what happens. Or at least test with a transfer size that is <= to your configured burst size. --- Quote End --- Hello Bob, Thanks for your post. I followed your advice but this didn't solve the problem. You can see my configuration at the picture (https://www.dropbox.com/s/d7174gyidtpgzqf/qsys_msgdma.png?dl=0, I need to do it that way because the forum does resize it when I upload it... unreadable...). I will keep on trying to get the msgdma to work... I'm open for ideas and hints:confused: Tom
