10 years agomsgdma stuck in busy state
Hello :) I have a problem with the msgdma. When I submit a descriptor to it and set the go bit it keeps in busy state. I'm using the SoCKit with Cyclone V and Quartus 14.1 The msgdma ...
10 years ago --- Quote Start --- Tom - What do you have the burst size configured to in the mSGDMA for the f2h_sdram interface? I had a problem with the mSGDMA that I've been meaning to open a SR about. In my case it was an Arria 10 SoC design and the mSGDMA was MM to streaming vs. your MM to MM. But my problem was also on the f2h_sdram MM interface. What I saw was that if the mSGDMA MM burst size (f2h_sdram interface) was smaller than the transfer size then the f2h_sdram interface would hang. If the MM burst size is smaller than the transfer size then the mSGDMA must submit more than one read request to the MM interface to complete the transfer. Let's say the burst size is 256 bytes and the transfer size is 1024 bytes. The mSGDMA will submit 4 256-byte read request to the MM interface in rapid succession (the MM interface buffers the requests). The MM interface then completes the first 256-byte burst transfer and stops. The mSGDMA is stuck waiting for the remaining three bursts that never come. --- Quote End --- Bob, I've been having my own issues with the mSGDMA and park mode, and am already 2+ months in to an SR about it. I'm a fan of getting SRs in, at least to get it recorded with Altera. I haven't seen this issue on a streaming-to-MM in 15.1.2 on a Cyclone V with Max burst=32 and max transfer much larger, with a 128-bit-wide interface.
